I have tested aboput all I can, with my 'no-charging'. I found bad connections at the terminals
on the generator, no continunity from wire ends to generator studs. thought had it !! removed
wires, filed the post nuts & terminals, good test then. Do get some volts on gen term now. 1 to 2v !
get 6v if I push regular relay in. I don't think system is working, as the engine dies if I pull
a battery wire. help. Thanks
