I was having trouble with tractor killing under load or on sharp turns and checked for loose wires. The wire behind the red indicator light on the dash that normally lights up when the key is moved to the on position was loose, so I tied the wires together-2 reds and 1 yellow-to bypass what appeared to be a damaged fixture. The tractor started and ran great for a while. I stopped to do something else and found the tractor would not shut off with the key do I killed by disconnecting the coil wire, replaced the coil wire, and put the charger on the tractor for about 2 hours. Now there is no reaction at all when I push the starter button and the charger pegs out when attached.
What happened? What is the fix?
