Show Parts for Model:
Re: Oil Pressure Issue with TO 30
07-17-2017 14:58:58
You have to pull the pan. I believe the relief valve spring & piston can be accessed without removing the oil pump. The spring is held in place by a washer and a cotter pin. Removing the cotter pin and washer should allow the spring and piston to come out of the relief valve bore. You can measure the free length(should be 2 inches per the shop manual) and it should take 8.25 pounds to compress it to 1.375 inches. It"s probably easier to replace the spring. If the piston doesn"t come out then the bore is probably plugged with sludge and you can possibly use some WD40 or mineral spirits, carb cleaner, etc and a piece of wire to clean the bore and get the piston out.
