Masey Furgeson TEA-20
12v Positivly grounded
I had initial issue not getting spark from the plugs so i replaced spark plugs and still same issue.
I noticed coming from the start swtich (solinoid) there was a blown inline fuse i could not replace this fuse out in the middle of knowhere so i thought i
would just wire it togeather and pray it would work....I tried to start tractor and then half the wire harness melted....
I have now tried to eleminate each part by remove it, the wiring harness now has the AMP guage, charge indicator (red light) and ignition key switch all removed and just wired togeather.
When i connect the ground to the battery BAMM same thing happens big sparks and the wires melt....
I removed ground and sanded the connections down and cleaned them well, tested with multimeter and all seems good.
I have no clue and im far from anyone that can assist me all i got is the internet and my shed, options?
should i wire it with heavy guage wire... i really got no clue why would they design something like this i got no idea?
If i dont slash soon im going to get over run with snakes !!
Thanks in advance,
Will keep tinkering
Wiring Diagram:
http://www.agriline.co.za/tractorparts/series_TE/images/tea20wiring.jpg
http://fergusontractors.org/nfs/wp-content/uploads/electrical/TE-TEA-20-6V-12V.pdf
Links on same issue:
http://www.tractorbynet.com/forums/massey-ferguson-owning-operating/274784-265-massey-blowing-fuse.html
https://www.tractorforum.com/threads/massey-ferguson-to-20.23867/
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ferg&th=115851
Image of ground going to starter bolt not like mine, mine goes to back of dash:
http://forums.yesterdaystractors.com/photos/mvphoto9497.jpg
Wiring Harness:
http://v2.ca-en.sparex.com/ItemDetails/ItemDetails.aspx?ItemNumber=67037
Thanks in advance,
Will keep tinkering
Wiring Diagram:
Wiring Harness:
