Sherman and a Howard??
Roger in Iowa
Does this Fergy have a Sherman and a Howard or other??
https://sullivanauctioneers.proxibid.com/asp/LotImageViewer.asp?ahid=1392&aid=127878&lid=36822209&url=2078-1.jpg
Sherman combo and a live PTO conversion. 99% chance the PTO kit no longer works, also a Sherman option. The wife's Fergy has the Hupp with Howard and possibly an Everett coming next year or so. Currently working on 881D engine rebuild.
As Bruce said sherman combo and sherman Live PTO. If both work can add value to the tractor BTW auction house has it wrong not a ferguson, its a ford Jubilee or NAA.
Kirk
If you've never seen nor heard of this, Ford N-Series tractor guru Marvin Baumann of Michigan built the world's one and only Ford 8N Four Trans Model. Having an offer to buy it from him a few years ago, he sold it. Since then he had so many requests he built another, called it FOUR TRANS II, and the rest is history. The II edition has the slowest ground speed of 12 inches per hour!!! He has tape measure and special pointer he made set up so you can actually see it work/move overtime because you can't tell with the naked eye. Check out his website and the other projects he has done -V8's in 8Ns and his TYPHOON II turbine tractor...
TPD
MARVIN BAUMANN & HIS FOUR TRANS II
