Michael QLD OZ
I have just installed an ignition tune up kit on my TEd20
First, I have never seen this tractor run. It was a seized rusted project when I got it.
So the engine now turns by hand crank and on the electric starter.
The only test I know for an electric coil is disconect the small wire from coil to distributor at the distributor end and also the HT lead from the distibutor.
Place the HT close to an earth.
Take the small wire and rub it along a stud or bolt threads that are earthed. This bumping from thread to thread earths and insulates the small wire, like circuit open closed open closed. So each time it is not touching a thread on the stud the Coil will fire a spark through the HT lead and I can see that.
So I believe the coil works.
I have checked the points closed I have 12v between each side and earth. Open I have 12v one side 0v the other.
So I think they are not earthed and installed correctly. Wothout the cap in place I can watch them open and close as the engine spins on the starter, no spark jumping that I can see, even in the dark.
But I have no spark at the plugs, I will dig out an old in line spark tester tomorrow and have a lash with that, but my usual suspect even with new parts is the condenser.
So after ALL THAT , can you tell me a modern part number for an off the shelf condenser that may be available from a local auto parts store, rather than waitin another week or more for an online source to post me a IGK5904 which is the listed condenser for TEA TED.
