Lifting engine points on Tea20 standard motor
kaesark
Hi
Am about ready to put motor back to Tractor and wanted to know if there was a correct way or lifting points.
Thanks
The correct way is the one where it doesn't fall on your feet. Don't ruin the head bolts, and keep a screw or hydraulic jack under the tranny to get the clutch shaft to line up. It took me 3 days to line up a live pto pack on my MF 30, so allow yourself enough time to do this safely and right the first time.
I always have the PTO Shaft engaged (Lever on side cover)FIG.3....turn the PTO OUTPUT shaft "Y" (Pliers or what ever works) to align the Input shaft of the Transmission with the steady bearing in the center of the Crankshaft as well as the SPLINES of the "TRANSMISSION INPUT SHAFT" with the Center splines of the "CLUTCH" plate:
A pic with info on FLYWHEEL Installation...IMPORTANT:
#12 puzzles me, but we ended up using a plastic pilot/aligning tool that came free with a Chevy/GMC standard shift clutch kit.
