TEA 20 Drop The Pump?
I finally summoned enough nerve to dig into my tractors hydraulic issues. I was expecting to find a stuck control valve. The rear end contained about an inch of dirt, with a thin layer of water over the solids and about 10 or 12 litres of diarhea. The control fork is not hooked to anything at the bottom. I have never done this sort of repair before and I will be working alone. Do I drop the pump or try to see it by going through the PTO shaft hole? I have heard that pulling the shaft is pretty easy.I can't see the valve through the side openings but then I might not know it if I was staring at it. The relief valve is obstructing my view.
There are those who would drop the HYD.Pump down through the bottom of the housing and NOT remove the LIFT COVER. I personally would remove the lift cover and then possibly remove the HYD.Pump. Your Tractor your choice.
Check the Internet for a TEA-20 SERVICE MANUAL:
I purchased mine through e-bay:
I've tried to supply pictures in a specific order:
See pictures and steps from FERGUSON MANUAL:
Bob...North Western Alberta Canada..
You may find that there is a bridge piece just above the pto shaft that holds the fingers of the forks together. It is shown in our Ferguson 20 parts list 819094M1 (Copyright 1957) page 6.
If you have this you'll have to release the bolts to get the forks to spread.
And I hope you have small hands
Good evening "Benj R" ......Fergie. and I are from the same Vintage..........:)
MF FE 35 is receiving a New HYDRAULIC Pump, Sooooooo, the TEA 20 was called up to service:
Bob....
