Mounting the Sherman 54c backhoe to the Ferguson 30
dsm137
And this is how it happened. Used the Wagner loader mount, added two bolts into the cover. Mounted backhoe mount to the bottom of that. Added steel plates to the sides of mount to drop rails a bit to level them out. Simple and worked well. Flipped the pump mount for front pump and drilled three mounting holes to mount loader. This moved loader forward enough to have it in the correct place to fit perfectly on the TO30. Great project!
