I replaced some of the linkage on the throttle recently,
and everything was working well.
(The tractor had set up for many years.)
Something has broken and the only way I can keep the
RPM from going to fast is to hold the throttle lever closed.
When I let go the RPM's go way way up.
The compensator spring and plunger to lever spring are hooked
up and look ok.
The governor lever seems to have more play than it used to have.
Also were the original running board made of checker plate
or like the ones for sale on this site?
up and look ok.
