Michael QLD OZ
Today I had planned to use compressed air to blow out the Cola I used in an attempt to dissolve any rust in my cylinders. So i removed the diesel injectors and applied the air gun. But in number 2 cylinder all I got was water. Fairly clean water, could this be coming from the cooling system. I have never worked with a wet sleeve engine before and am on a steep learning curve.
The engine is seized so 90% chance the head has to come off, as I have tried every suggestion to free the engine.
