I bought my TO-20 last year. What a beast! Fired right up after sitting all winter. Love it!
I have a slow dripping leak from the 5 or so inch diameter access plate on the bottom of the oil pan. I cranked down on the bolt holding it in place, that slowed the dripping down but did not stop it. It drips constantly enough to require attention. This may or may not be caused by me driving over a smaller sized tree when my steering stopped turning me at the last second...
Is my understanding correct, that this plate houses the oil filter??? I am not familiar with that design.....
Its time for an oil change anyways, so I'd like to replace the oil/filter/ and whatever gasket fits that access plate all at once. Can anyone recommend a source for those items? I have found these links here, but I am not sure if this is the gasket I need?
http://www.yesterdaystractors.com/1750269M1_Oil-Filter-Gasket_22770.htm
The oil filter says it comes with a gasket - but I assume there's a gasket for the filter and another for the access plate?http://www.yesterdaystractors.com/Ferguson-TO20_Oil-Filter_APN6731B.html
The manual I found online says it takes 6 quarts, but also to add another quart when changing the filter... so that makes 7 quarts...is that right?
It also says to "shellac" the filter gasket to the cover plate to prevent leaks. Shellac - like the wood finish? Never heard of that one.....
Sorry for so many questions! Much obliged.
