Michael QLD OZ
Well my engine appears to have moved just a little bit over night.
I removed the plugs and horror,, found a rusted tip on number 2.
So filled the cylinders with a mix of ATF and Racing A, cause I had no acetone left.
Theory is the racing A thins the oil for penetration then evaporates slowly leaving the oil for lubrication.
Then i lifted the front of the tractor and put the crank handle in then supported it with an axle stand and lowered the weight of the tractor onto it.
I took a photo last night and then felt that it had moved a bit this morning so lifted the tractor again and made the axle stand higher.
I have posted the photos back to front this mornings first then last nights
