fordmann78
New User
Hello guys, 1949 to20. Pin fell out of the control arm and landed between a piston and the housing. It broke a piston. Rebuilt the pump. Reinstalled the pin. Before I tore it apart the lift was stuck in the up position. Filled it up with fresh 90 weight oil gl1 oil. The 3 point lifted right away again even with the control all the way down. All linkages are free. The lift arm moves almost too easy, it's very floppy. The fat part of the control valve moves freely. Is there anything else behind the control valve? I saw on a couple diagrams that there could be a long rid behind it? Any input would be appreciated. And no the spring is not broken.
