Crankshaft Specs
TonyRSnyder
New User
I have TO30 with a remote hydraulic pump mounted on the front driven directly from the crankshaft. The shaft for the pump is .75" dia with two key way slots and it slides into the front of the crank. The shaft I have is damaged and I need to know the key way slot dimensions on the crank so I can have a replacement shaft made to connect to the pump.
Any help here would be appreciated.
