t0-35 and F40 power steering
i am going to buy and put to-35 engine in my F40. The TO doesn't have Power steering block/engine. Can it be adapted to use the F40 power steering? Or am i out of luck? thanks for any input also, asked in MF forum sorry for duplication. Will most other parts interchange from the TO-35 to the F40?
Sounds like a risky proposition.
There are quite a few differences in a F 40 and TO 35.
The front suspension is different, that could be an issue with bolting to the engine, not sure, but something worth looking into first.
As for the power steering, without the mount hole in the block for the pump, you will have to try to adapt some kind of automotive pump and belt drive it...
My recommendation would be to find the right engine unless you've already bought the TO engine, and got a really, really good deal on it.
The Z134 some blocks have a cover where the power steering will mount the first blocks do not. I have a 1958 power steering tractor with a hole in the block from a rod that I am going to put on a 1957 to35
