Re: TEA20 1954 Harry Ferguson Tractor
Here's my issue -
I am replacing most of the wiring on my tractor and the issue I'm going to have is I have a 12volt alternator which somebody must have changed the generator out years ago - now I'm sure I can use the (control box - voltage regulator) but I'm having some trouble where I should connect the P1 wire which comes from the alternator - and where I should connect the (F) terminal on the Control box/voltage regulator. Maybe the F - should be wired to the negative on the battery?? However the (A) terminal on the control box/VR should go to the key switch / which should wire through the tractor to the .5 ohm resistor to the coil then to the distributor.
This leaves the (P1) exciter wire from the alternator - this usually goes through a indicator lamp then to the key switch however the (A) terminal from the control box is doing this. Can any one help ??
thank you,
Stan
Here's my issue -
thank you,
Stan
