Hi - I have a SEA20 1954 Ferguson
I am trying to replace the Voltage Regulator - I'm not sure what connects to the first terminal? The second terminal was a bond to the tractor frame the the third terminal was hot from the battery and the forth terminal was just corroded off - so no wire was connected. Can anyone help with the wiring? I purchased a new (control box) which has a terminal on both sides and I'm hoping there's an additional two terminals when I receive the part.
thank you,
Stan
thank you,
Stan
