Hello,
I just purchased a 50-51 TO20. Was running fine. Went out to start it and would not turn over. When ignition switch is off I have 4.5 volts (6 volt system). When I turn on the switch voltage goes to 0. disconnected the coil no voltage issue so replaced today. still having voltage issue. When I separate the points voltage issue goes away. Is it the points or the coil? or is there something else that I'm not thinking of?
