I think my to35 is done. I had a head gasket put in due to water in the oil. When the dealer broke it down he said sleeves and rings looked good and I should be good to go. Well it did run fantastic. Bush hogged a couple of hours and let it sit until the next day. I opened the oil drain plug and same problem, antifreeze came out first, about 1/2 quart. I have to give the dealer credit he came right over and picked it up. He took the engine apart again and found 3 block cracks and said his fault they didn't see them.
here's my options, Friend of mine said t get a ball value the truckers use and replace the oil drain plug with it. Open ball value after letting it sit overnight and drain the antifreeze out and shut it when the oil appears. and it should last for a while. Dealer said he could put a MF50 engine in and it would have a little more horsepower. (any thoughts on that) and the last option .... He has a Kubota L355SS diesel with 2900 hours he would let me have for a good price because he said he will make good on the initial labor charges for the head gasket. Also he will auction off the TO35 and deduct the price from the Kubota or hand me the money. [b:014ec92ff3]Any opinions would be greatly appreciated. Just to add... rear tires are new, 3point works flawlessly, new water pump, air suspension seat, and I added and electronic ignition.[/b:014ec92ff3] I'm really bummed out about this
