I have a TO30 that came with the property we purchased. This tractor stayed outside for quite some time. I have since cleaned an area in the pole barn so it is sheltered.
It appears water leaked from the shift lever boot into the transmission so I need to change it.
Underneath the tractor there seem to be two drain plugs. One near the clutch next to a cotter pin looking port that I was told was to keep oil from going into the clutch. The other is underneath where the PTO lever is located.
First question is do I remove both plugs?
Second question will pouring new oil into the plug on top of the transmission fill both reservoirs, if not, then how to fill the one near the PTO.
Thanks
Robert
Thanks
Robert
