New wiring , new plug wires , plugs good, new rotor, points and condenser , cap good, but one on order anyway. Fuel line checked, carb rebuilt. New battery as well. Ran perfect, aside from the accelerator being adjusted too tight and wanting to idle back down, which was temp solved by holding throttle lever, cause I needed to get the weeds in front knocked down right away, after an hour and a half, I shut down to eat some lunch . Decided to put my scaper blade on to get some left over stubborn weeds that my dragger couldn't get. Started fine, backed 25 feet to scraper, and hooked up, pulled around front, 25 feet, started heading toward other side of yard to pull back toward the way I came, and tractor started sputtering, double checked gas valve, jumped off and unscrewed gas cap to make sure there wasn't a venting issue , didn't change anything, after several moments of this I decided to head back to park the tractor , and address issue. The Fergie sputtered then died. After several tries, I was unable to refire it. Any suggestions ? Did I miss something ? Where do I start? Can someone help?
