Hi
I have a Harry Ferguson TO30 and noticed the transmission hydraulic fluid level was low. I went to the store and purchased some 90w fluid and filled the transmission. Next day the fluid had dripped onto the ground. Noticed there are two plugs underneath the tractor with one having what appears a small metal 'cottter pin' that moves in or out if you push on it. I was told that was to keep fluid from entering into the clutch.
Does this mean there is a gasket that is worn or does the plug need cleaning, etc.
Thanks
Robert
Thanks
Robert
