glennster
So I had the new to me fergie out running anound the farm today, pretty muddy and didn't want to get a bigger tractor stuck. Anyhoo, when cold
I have 25 psi oil pressure just above idle. After running a while about an hour, the pressure gradually drops and at about half throttle I get 10 psi
steady. Oil level is full and the oil is clean. P owner did change the oil. Is the oil pump serviceable ? On the farmalls, the lower oil pump cover
wears, and a little machining gets it back in service.
