Serial Number
MDeLong
New User
I'm sure this has been asked many times. Just picked up a Ferguson with a serila number of TO-3544. The hood has been painted and has TO-30 on it but in my research I may have a TO-20. Please set me straight. Thnx
First of all did you find this number on "TOP" of the dash between the steering column & the hood? I am guessing you are saying the hood emblems are showing Ferguson 30? Is this correct?
Do you see the oil filter housing on the right side of the block? If you do there should be a air intake on the right side of dash and the key should be installed on the top left of the dash on what is referred to as the bump. If this is all correct maybe somebody found a serial plate some where and put it on as theirs was missing. The TO 20 serial numbers went from 1 to 60000. The TO 30 serial numbers went from 60001 to 140000. Please check the serial tag again to see if you missed one or two numbers.
As the years go by,these Tractors tend to have parts and components swapped:
Part # 36....TO 20:
Part # 28 ...T0 30:
ORIGINAL PARTS BOOK.....
I have what I have been told, and as far as pictures show, is a TO20 with a TO30(Z129)motor,But my question is. How can I tell what year or approx. year it is, if the serial number plate is missing?
