to 35 z134 engine, have installed new governor assembly (shim not installed) adjusted governor linkage by John UK instructions from this site. with throttle rod removed from governor lever and engine running have no resistance from governor rod,with engine stoped this lever has 1.25 inch of free travel.lever is free in bearings,the governor tapered cone is installed with tab to 12 oclock . can somebody outline proceedure to determine if shim is required .It seems to me that the movable cone does not contact the lever in case although is properly installed and not worn. the movable governor cone is free in camshaft and drain hole is open. this has me stumped and need some help Thanks
