Where to start liners,crank or cam
kaesark
Hi folks.
Have finally got everything back from the reconditioners including new engine kit.
I was planning on reassembling starting with Crankshaft, Camshaft, liners and pistons.
Any issues with this sequence or am I clear to go.
Thanks.
Ha i have just finished a rebuild. I did the liners before anything and part fille with water to make sure the liner gaskets where sealing properly, then crank, pistons and cam when getting the timing setup.
Good luck :D
You own a manual? It will tell you the order it must be re-assembled in. You don't want to nick something or take it all down twice.
(1) Service Manual........Available on the internet........purchased mine on e-bay...Originals:
(2) Cleanliness....
(3) Follow the Service Manual steps.........
(quoted from post at 17:38:43 03/10/17) Hi folks.
Thanks.
Ha mate.
If its a tea20 with standard motor, then if you want a how to you tube experience what this bloke. its useful if your a first timer engine rebuild, like me.
https://www.youtube.com/watch?v=lb5NUpKFjlI
this is part 3 think there are 5 videos.
Other tip google triump TR3/4 as same motor at the tea20.
Wow that's awesome got some good tips too,
cutting the felt sealing strips into
segments made a lot of sense too otherwise I
was scratching my head.
Cheers
