Ha guys.
I have a genny and 3 regulators setup on the bench for testing, spinning the genny with a drill.
2 work one does not.
The one that does not work, i have pulled apart and cleaned all contact points, check resistances and connectivity against one the good regulator
The faulty regulator. The cut out relay works the same as the good reg, also does the voltage regulator relay seem to work.
So physical the regulator seems to work, but i get no increase ( or change in voltage) from the A terminal on the reg.
On bad reg i get 12 v out of the D terminal on reg where as i get 14 + volts on good reg which is then regulatored by the VR relay.
So this tells me that with bad regulator connected the genny is not outputting 14 + voltage with increased rpm, which seems odd, but thats electrics for ya.
Any ideas, I ve spent to long done the regulator rabbit hole
