TO30 rebuild
Ticranch
New User
New to this forum and completely new to tractors. Picked up a TO30 tractor and found water in the oil. Pulled the engine apart and found it has cracks between each cylinder. Also the crankshaft is worn beyond .30 so assuming it's trash. If I can find a way to fix the block I can justify a new crankshaft and rebuild kit. Any ideas on a fix for the cracks?
if the cracks are only at the top of the block a new head gasket may do the trick. if the cracks are at top and bottom and of block then a new block or a procedure known as "pinning" may be a fix.
If it helps, I have had two TO30's pinned and rebuilt. It is worth it. The last block done cost 250.00 to pin
