to30 VALVE REPLACEMENT
bruizer53
New User
Ok so im in the process of completely redoing the head including new valves, rocker assembly, and a refinished head. I bought the valve overhaul kit off this site and now that i have the head together i realized the kit didnt come with valve seals or the caps to go on top of the valves. Thoughts? do i need valve seals and should i be reusing old caps? not even sure i still have them i assumed the kit came with them
Seals should go on the intakes.
As for the lash caps, if the old ones are good, flat with no dips or ridges, they can be reused.
Note the intake and exhaust caps are different.
# 9 Intake Valve:
# 10 Exhaust Valve:
Info was obtained from YT Ferguson Tractor Forum in the past Two Years,then recorded in a Parts Book I own:
No guaranties of info accuracy:
Is Info correct ?
Is info incorrect?
(quoted from post at 20:28:06 03/02/17) Seals should go on the intakes.
thanks guys. Ill just buy new ones since i have to order the seals anyways. Im trying to do everything right, i love this tractor and would rather spend the money now than do it again later
