TO-20 steering box oil seal removal
Some of this may depend on if you want to keep it looking "ORIGINAL" or not. If you don't care if it is original looking you can grind off those centering nubs on the drop down arms then the seals will come off after you unhook the steering link assembly, or some call it tie rod. If you want to keep it looking original "big job", you can take the steering column off the tractor & take the bottom plate off & take the drop down arms out. Usually a screw driver can be used to pop the seals out. You can go to page 4 and go down to the 3rd article that may help you also.
