Has anyone else become fed up with trying to keep the water out of the transmission of their Fergie? I know I have. Seems that no matter if you have replaced the rubber boots around the shifters or not, the water always seems to creep in. The new boots you buy are weather cracked within 12 months anyway. Aside from parking it inside all the time or tarping it after every use, what else have you tried?
I've been thinking about fashioning some little umbrellas that I will hold in place with hose clamps around the shift levers so that the water can just run off.
I guess on the bright side, it makes me change my fluids more often than I probably would otherwise!
