TO-20 Oil filter plate bolt
Warus
Hello, does anyone know where I can purchase the bolt & washer that goes thru the oil pan cover into the oil tube assembly?
I think the bolt is part# Z120B-201 but I can't seem to find a match anywhere.
Thanks in advance for your help.
/Dave
That is just weird enough for me to pull out the 1973 parts manual. . .
Bolt, Cover to Tube, Prior to serial number 48607 is 1 750 310 M1
Bolt, Cover to Tube, Serial number 48607 and up, is 1 750 272 M1
Gasket, Cover Bolt 1 750 355 M1 (1/2 X 1 X 1/16")
Gasket, Cover Bolt 1 750 356 M1 (15/16 X 1-11/64 X 1/16")
You might contact your local tractor dealer and they can assist you with the 44 year old part numbers.
Question to you is the serial number of your machine.
That is just weird enough for me to pull out the 1957 parts manual:
Numbers same as supplied by Bruce(OR):
Bob...
Thanks to everyone.. mine is a 19896.
I'll call my local MF dealer and see if he can get me one.
(quoted from post at 23:24:56 02/17/17)
(quoted from post at 05:27:10 02/17/17)
I think Dave's referring to the serial # of his tractor. But I may be wrong. :wink:
BillL
Yes, 19896 is my tractor serial number
