Mf 135 won't start
Gregrobison
New User
Mf135 1968 model won't start. It turns over strong enough to start, but won't. I went out the other day and it started immediately. It ran open throttle. I tried to adjust throttle but ran at same rpm. I killed it and it's back to just cranking, nostart.
If the fuel is in deed being supplied from the transfer fuel pump to the main injection pump? there is very possibly something wonky inside the main injection pump? Check to verify the throttle linkage as well as the push pull stop linkage is connected properly?
(quoted from post at 21:48:44 02/14/17) If the fuel is in deed being supplied from the transfer fuel pump to the main injection pump? Yes I bled the system all the way to the injectors
there is very possibly something wonky inside the main injection pump? Will check
Check to verify the throttle linkage as well as the push pull stop linkage is connected properly? Seems fine to me
Once you verify you have fuel UP TO the injection pump..
There are many, many videos and write-ups about getting the top cover off and freeing up a stuck metering valve on a CAV pump.. Google is your friend on this one..
(quoted from post at 17:18:34 02/15/17) Once you verify you have fuel UP TO the injection pump..
Thanks everyone. You've been helpful in pointing me toward the problem.
