Hi Folks
Seems to me every time I go to touch something on my Fergy TEA20 i find anomalies, was busy grind away surface rust from rear rims with center removed in preparation for galvanizing when i noticed that the lugs on one rim were welded on and this rim was slightly wider being 280ml also the center hub is of thicker metal. The other rim is 260ml and the lugs also have what appers to be rivets assisting in keeping them fastened to the rim.
I suspect the narrower rim is the original and the wider may be off a Fergy 35.
Your thoughts please would be most appreciated.
