Scarboroughseadog
New User
I know there are similar threads but I cant seem to find just the answer I am looking for.
I run it on straight petrol and am trying to find the correct sparks to use.
I had intended to replace the current NGK BR7 ES (3/4" thread) with Champion N21 (3/4" thread)
Is the Champion the correct spark, and is there any material difference between these 2?
On reading similar posts I wonder if I should be running 1/2" threads?
A bit lost as to whether either of these run at the correct temperature?
What's the correct gap setting for these sparks?
Do I need to adjust the dizzy at all when changing spark types?
I have variously been recommended either of the above, Champion L86C, L90C or NGK B6HS or BR5HS
Bit of a minefield- any assistance appreciated!
Many thanks!
Many thanks!
