TO-30 Front Loader
dcburn
Hey guys I have a 1953 TO-30 with a front loader. I haven't found any literature on how to reinstall/use. Would like to be able to clean out coop
and pig stalls, move some hay bales etc, nothing that amounts to any weight. I can attach a pic, I think I have everything. Obviously hydraulics
probably need rebuild and new hoses. Any help would be greatly appreciated...
If you can tell what brand and/or model of FEL (front end loader) you have that could help others with their answer. Sorry I can't help you.
Hi, include some pics so we can identify the loader to help. Is there a separate pump motor that attaches to the front of the engine?
As Tom said, tell us if it has a front pump or not. The front pump is key. If it works good, the lines are not a big deal to replace, but if the pump is no good, that's expensive. Wagner made a lot of the loaders for the TO-30 and Ford 8N and they will transfer between those two tractors fairly easily. Be aware your steering will be very hard with a loader. If the tractor steering is in good shape it will work, but it will steer pretty hard. Wide front tires help and you will need a nice weight on the back as well as fluid in the rear tires. Post the pic, and especially the pump pic if it has a pump. Wagners sometimes have a model number on the upper right of the structure.
(quoted from post at 08:48:34 01/13/17) Hey guys I have a 1953 TO-30 with a front loader. I haven't found any literature on how to reinstall/use. Would like to be able to clean out coop
Are you near eastern Pa?
