Te20 Distributor shaft
dfitch
I have a lot of play in the distributor shaft on a te20. Can that be
repaired and if so where can I get the parts. I don't see any listed
at YT or Stiener
If you decide to service the DISTRIBUTOR here are some valuable steps. Pleases note the UNBELIEVABLE fix that someone had done to the mechanical advance........LOCK WIRE!.....This showed up when I installed the distributor on my test engine. My test engine has 145 teeth on the ring gear. 360 deg/145 = 2.48 deg per tooth. At 2600>2680 RPM of engine the TIMING was NOT 25 Deg (10 teeth) but rather O deg. The drive TANGS are ready to fail on another Dist. drive.Before you disassemble your distributor you may wish to read these instructions. Next time I shall try to obtain SEALED BEARINGS.
