Hi
This is the air cleaner off my ted20 that was causing it to run rich. You can see why. This is off an 1951 and the bottom of the air clean is spot welded on so drilled them out then found 60 years of crude. No wonder it was running rich.
I had already soaked this in petrol or kero, but it did nothing.
so its worth takinge it apart to clean.
Hope this can help someone out..
