54FergieTO30
I had the flange type front main bearing in the block. The new bearing set is the flange-less variety. Two identical thrust washers (not sure if that is the right term) came with the set. They both have the 3 holes in them. I understand one will line up and sit on the pins on the outside of the block.
My question is involving the one placed on the inside that takes the place of the flange. What keeps it from just spinning around with the crankshaft? I am also not sure which side of the washer should be facing the crankshaft.
I have not reassembled yet, I don't want to screw this up.
Hopefully someone out there can help a rookie with this engine overhaul.
By the way, it's on a 1954 TO30 that I have had for almost 20 years. I do not want to mistreat this motor, it has no block cracks and has served me very well.
