RedGreenGuy
I have a TO 35 Deluxe. The hydraulic/rear end cover is cracked as is a small crack at the front of the
entire rear end case. The crack is at the left front corner on the top and into one of the bolt holes
for the top cover plate. I found a complete rear end with a good cover plate, but its from a standard
tractor. Can I use my parts and convert the standard to a deluxe? Can the crack ( 1 1/2 ") be welded?
Or do I look for a deluxe rear housing? Or part the tractor. I would like save it.
