to-30 lift cover
My to-30 lift cover has a crack right across the top of rockshaft bushing carrier. Before I send money to the parts houses, anyone here have a to-30 or to-20 they are parting out? Thanks in advance
Uh...yes. I am in Oregon. Email is open. It's a TO-20. You are aware that 2N and 9N also use the same cover, right? That is why the wife's TO-20 will get 8N top cover and pump. The 8N has different cover and pump and if you desire the built in position control, you need to change out both of those. Think that might throw a few people for a loop?
I might have one in NJ. They are pretty heavy to Ship. If you
could stay local it could save you some cost.
Kirk
I did not know they were same as 9N/2N and so I will look further. If I am home beofr dark I'll look.
they are kinda heavy to ship, but actually all I need is the casting and none of the apparatus inside. I dont even need a rockshaft.
This to-30 has a Pippin excavator and it mounts to the tractor at the rockshaft and at the attachment bolts for the lower lift arms. The machine has a lot of slop and some shock must have cracked the lifft cover casting.
Thank you
Bill
9N, 2N and the TO-20 are the same on a lot of parts. TO-30 is supposedly the same as the '20. That I should actually look in my Fergy parts book, but I do believe it is the same animal as Fergy was the one who designed it and Ford changed it. idiots. Had Ford and Fergy stayed together, it would be a case of "What's a John Deere?"
