darntractor
New User
Sooo, I have a to30 that I twisted a pto on. I have actually been working on and off on this since spring and I have finally friggin had it with this problem.
I cut the PTO behind the pump but try as I am I could not get the pump to drop out the bottom. I decided since it was twisted in front or even in the pump I needed to split the tractor. I removed the bolts and everything on the outside of the tractor.. exhaust and etc.
It will not split. I can get it about an inch apart and then it seems the pump is still holding it in. Any ideas would be greatly appreciated. I am close to junking the thing. I just can have it in pieces in the shop any more.
I have been through the manual a dozen times. Just out of ideas
