JonwithanM
I need to rebuild the carb on my TO30 sn 127037. I pulled the carb and it is stamped in various places Carter 838 ut 0-839. I am thinking this is a UT carb and it seems not the right one for this tractor??
It was running fine but the needle pin stuck open and I found the gasket for the float bowl was coming apart and sticking the needle open.
Is this carb correct? and which rebuild kit do I need.
Thanks
Thanks
