Massey Ferguson 300 Combine
Rob Benton
New User
I have a question about a 300 Combine. It has been sitting for at least 10 years. It had been inside. I can buy the machine fairly cheap. It has a 13' header with a U2 real and a floating cutter bar. The only thing I've seen wrong is the lower bearing in the unloading auger is froze up. Is this machine worth saving?
I spent a lot of time in an MF 300 combine.
Don't know how readily available parts are any more. That might be an issue.
They sure don't have much capacity. I wouldn't want to use one again after having been in much larger combines.
No way we can tell you if it's worth it for you to buy it. If it's cheap enough and you have the shed space for it, why not? These things are old enough that if you get it running you might find a collector who would like to have it. Would be something unique to take to shows.
