Throttle linkage
TO-30GUY
New User
Can't find the part number for the ball joint linkage part that bolts to the U-bolt and goes to the governor, any help appreciated thanks.
(quoted from post at 19:35:01 11/17/16) 187688m1. Put it in a search and a lot of sources come up.
Is that the one that is right next to the water pump directly above the governor? I'm having a hard one telling which one is the right one and which is the one that is farther back near the driver and the actual throttle lever. Thanks
Here is a picture of the part number I listed. Is this the part you are looking for?
I need to know the spring setting for my pump both sides... trying to bleed no luck yet pump was totally froze up just got it clean and think it is trying to pump but will not come up lines yet. not sure of spring settings just guessing from some stuff i read. here is a picture of one like mine. It is a 1959 TO35
b-c by the looks of your picture this is a CAV pump which would be what is used on a 20 or 23C diesel, correct? you should start a new thread rather than adding to this one you will get more responses.
Since you mentioned that the pump was locked up, did you completely tear down the pump and make sure the shaft wasn't broken? Does your motor have glow plugs? Take a picture of the pump side of the engine and include in a new thread
