Ha guys.
The motor is total stripped...
I have measured everything and check against the specs best i know how.
Main question. The pistons at the top measure 83.85 to 83.96 mm. Specs call for 84.905 to 84.933 with no worn allowances in my maunal.
Sleeves are roughly 85.1 specs call for 84.988 to 85.016..
I measured this with vineer calipier so igs might be slightly off.
some of the sleees have a ridge at the top.
Want to know if i can re hone linears and fit new rings and have an acceptable engine. I feel i would like to keep the old pistons etc, seeing the quality of stuff that bareco etc supplier.
So is this doable or should the sleeves pistons be replaced.
I ask as some of you know i rebuild an inframe ted20. I replaced all rings in that engine and had to replace one linear. How ever doing a compression test i get 70 to 75 psi across all cylinders. So that suggested you either do the hole engine kit rebuild or rehone linears replace rings and have a 75 % engine??
Here are some pics...
No 3 journal needs fixing as is under size compared to the others.
