Z129 Connecting Rod Orientation
TO-30GUY
New User
Which direction does the oil spray port on the rod face? The cam side or the non cam side? I have the ports facing the cam side but I want to make sure. Reading the manual and it's talking about stampings but my rods do not have numbers on either side. I also have the new pistons set up so the dot is towards the front of the engine. Correct me if I'm wrong. Thanks in advance.
They need turned around as you have them now, oil is sprayed on the thrust side of the sleeve which is opposite the cam on that engine. Rod cap #s will go to the cam if there.
