Ferguson Disk Plow for sale
you are right someone should buy that old plow, not many of them left,
they plow where flat bottom plows fear to tread.
also look cool at shows
attached is a picture of one my friend and I bought, does a fine job, we had to replace the rear guide blade and add a little paint and powder.
many times that is what happens to old disc plows, the rear guide blade wears down and will no long hold the plow going straight, farmer quits using it, rather than replace the guide blade.
again, as you said someone should buy it and restore it, not let it go to the scrapper.
One of the advantages of a disc plow, they will roll right over an obstacle like a root or rock,
Not get caught under or break,
Cowboy,
If you buy the plow,
old wife's tale,
A Ferguson plow wrench was shipped inside the tube of each of these plows,
Do not know if this is true as I never looked inside either of the one's we have,
Would be worth a look if you do not have an original Ferguson plow wrench,
These plows were called "bullet plows as their frame does somewhat look like a large bullet"
Note to file, not everyone has one of these plows, we looked a long time here in west ky before we found our plows,
go for it, of course try to get it cheaper if possible,
you will not meet another one coming down the road,
this one is like mine, a later model, some call them the bent tube model.
works good, the ID plate on mine: MF64 disc plow
I think I paid about $200 for this one, however, it was located in the back side of
no-where's-ville, TN, they did not even have cell phone service there.
Trying to get the owner to send more pictures, I want to be sure it is complete and has the tail wheel. I notice the there is at least 1 bolt in the back of the frame, why would there be a bolt in one of the back holes?
Yes, I have heard about the wrench inside the tube, hope I get to find out if this is true or not
