Little advice
Armand
I have read the various way to winter over a tractor. I have a 1955 TO35 which will be in the garage over the winter. Instead of going thru all the ways to winterize is it okay to start it up every 2 weeks or so and just go for a spin around the field. I have done this with the riding lawn mower in winter and snow blower in summer without any issues. Any thoughts?
If the tractor had not been run for a few weeks,
You might open one of the transmission drain plugs enough to let a small amount of oil run into a glass container
Chech to see if you have any water in the bottom of the sump,
Water will separate from the oil in the bottom of the sump after a few weeks,
If so you need to drain enough out to clean the water as your hyd pump sets low in the sump,
(quoted from post at 19:30:45 11/06/16) If the tractor had not been run for a few weeks,
thanks for the tips guys.. I did add stabile to the gas already and I will check the trans oil. Thanks again
